Syncovery on handheld windows PC - LegioN Go / Ally
apd123
Post by apd123 »
I was wonDering whether anyone had any experience of using Syncovery on either of these devices without an external monitor. They both have very small screens (which is my concern) but - if Syncovery works - could be an excellent solution for backing up and verifying photos when out on location and then uploading to the cloud in the background. A slightly expensive solution but should be reliable.
Any thoughts on Syncovery on such a small screen welcomed
Re: Syncovery on handheld windows PC - LegioN Go / Ally
I don't think many forum members have tested this, but I checked the specifications. The Legion Go has a screen resolution of
2560 x 1600 pixels
Which is rather a lot, more than many office monitors still in use today. Syncovery can be used with much lower resolutions.
So if a dialog box doesn't fit on the screen, you can just lower the magnification factor in the Windows screen settings.
You need to be able to visually read small fonts though.
apd123
Post by apd123 »
Thanks Tobias. My 2 concerns were seeing the whole window (which I think is not an issue). The tiny fonts may be more of an issue. I'll continue thinking about this.
If only there were an android version....!!!!
