Access Problems
rbartusik
Access Problems
Post by rbartusik »
does anyone know what Access problem (Critical Section Hang: GSMBCS, Checkpoints: ClAllFX @0000000000540110) means, an example is
10/30/2023 08:20:36 ERROR (Exception): Critical Section Hang: GSMBCS @ 0000000000540110, Thread ID: 140361265571392, CP: MSPEX (CallFindNext)
Exception Critical Section Hang: GSMBCS with TCP=MSPEX
10/30/2023 08:20:36 ERROR (Exception): Critical Section Hang: GSMBCS @ 0000000000540110, Thread ID: 140361265571392, CP: MSPEX (TraverseTree)
10/30/2023 08:20:36 ERROR (Exception): Critical Section Hang: GSMBCS @ 0000000000540110, Thread ID: 140361265571392, CP: ClAllFX (TraverseTree)
Traverse Exception Exception: Critical Section Hang: GSMBCS @0000000000540110, Checkpoints: ClAllFX
10/30/2023 08:20:36 ERROR (Exception): Critical Section Hang: GSMBCS @ 0000000000540110, Thread ID: 140361265571392, CP: ClAllFX (Traverse)
10/30/2023 08:20:43 ERROR (Exception): Critical Section Hang: GSMBCS, Checkpoints: ClAllFX @0000000000540110 @ 0000000000540110, Thread ID: 140361582122560, CP: ATTHRF (BuildFileList)
Error building file list: Exception Critical Section Hang: GSMBCS, Checkpoints: ClAllFX @0000000000540110
Stopped due to "Failed" (1)
if anyone ould help that would be great
Re: Access Problems
thanks for the report. It seems that the SMB network communication hangs.
In such cases please avoid the internal SMB protocol and mount the network path using your NAS' administration area / file manager, or using Linux tools.
rbartusik
Re: Access Problems
Post by rbartusik »
it is odd half of them will run and half of them will have that error, is there a reason that it is doing that?
Re: Access Problems
No idea, sorry, but I will change it to allow longer delays before erroring out in the next version.
Re: Access Problems
the new version 10.8.3 is now available and it will no longer throw this error. Profiles may appear to hang if there are SMB issues though, but should eventually recover.
