Hello.
The Restore Wizard option does not work as it should. When doing a full restore and selecting some folders in the process, the filter is ignored and restores all files in all folders. I tested on 4 different profiles.
Syncoveru 10.7.0.
Thanks.
Syncovery Restore files ignores the filter
tiagocoelho2
- Sync Restore.png (31.72 KiB) Viewed 12866 times
Re: Syncovery Restore files ignores the filter
thanks, I will test it.
In general you will get the best results if you choose to save the restore job as a profile (see the last tab sheet of the Restore Wizard), then cancel the restore operation and edit the restore profile to match your requirements more precisely. That way you can run it and test it multiple times without having to use the Restore Wizard every time.
tiagocoelho2
Hello.
I already created the restore profile, this was just a demonstration of what the bug is about.
