Password rejected - Couldn't open Syncovery
ChaosX
Post by ChaosX »
Running the Synology application, and my login credentials would not authenticate today. Stopped and restarted the package without success.
Manually installed the latest 9.48n and the credentials were accepted.
I never saw this before. Any idea what happened? Is there a "simple" fix, as I think I lucked out with the new install.
I had 9.48 installed IIRC (earlier letter version).
Re: Password rejected - Couldn't open Syncovery
I don't know what happened, but the password can be reset via an SSH shell command. You can connect with PuTTY and log into the SSH terminal.
The command line can be like this:
SyncoveryCL SET /WEBSERVER=localhost /WEBUSER=username /WEBPASS=password
You may need to cd into Syncovery's program folder first and then use ./SyncoveryCL instead of SyncoveryCL.
Where username and password can be chosen freely. However due to command line constraints the password should contain only ASCII characters and no special characters such as ! or " etc. unless you can properly escape them in a command line string.
ChaosX
Post by ChaosX »
Thank you. That's good to know.
