Encryption on Synology Devices
Simplytoast
Post by Simplytoast »
I am trying to run Syncovery directly on my NAS rather than on a dedicated computer. I am trying to mirror the profile but earn it comes to encryption I am able to use the SZ format but for the encryption type I can only use "Zip Compatible" rather than AES-256 which is on my Mac.
Is this intentional? On an Intel64 Synology on DSM7
Re: Encryption on Synology Devices
please choose ZIP-compatible AES 256. It's the same AES-256 that you can choose on Mac.
In the HTML web GUI, the same encryption choices are shown for both Zip and Sz formats. But only the first choice (AES 256) is supported by Sz.
It does use the same algorithm as for Zip, but of course since the container is different, it's not really zip compatible. So the label is wrong.
Simplytoast
Thanks for that. I find it weird I imported my profile from the Mac, added my encryption passphrase and seemingly it wants to re-upload everything (seemingly it is unable to decrypt the right hand side).
If the filenames are encrypted, that could be a problem.
Does the password contain any non-ASCII characters?
Simplytoast
Yes on the name encoding but I only have ASCII characters in the password.
Guess we will stick with the native Mac app then :)
