sort profiles
mekd
sort profiles
Post by mekd »
Is it possible to sort profiles? Or change the order they appear on the main window?
Re: sort profiles
profiles are sorted alphanumerically. In addition, they are grouped by the first word in the name.
So if you have multiple profiles named
Backup Office
Backup Database
Backup Work
Sync Office
Sync Databsae
Sync Work
then you will get two groups named Backup and Sync.
mekd
Re: sort profiles
Post by mekd »
Thanks. I thinks its very limited.
You should add a feature to drag and drop profiles so one can re-arrange the profiles as he wishes. I for an example would like to put a few profiles at the top of the list regardless of the profile name.
Re: sort profiles
Yes, eventually this will be made possible. For now there are a few more pressing areas to work on.
