Syncovery Web GUI Error 10049. Web server could not start.
tiagocoelho2
Post by tiagocoelho2 »
Hello.
After installation, restoring settings (Syncovery.ini and Status.ini) and rebooting, the syncovery web service does not load automatically. After 1 or 2 reboots the system works again.
WebGUI.log
23/04/2022 04:53:02.090: Loaded SSL Certificate for *.xxxx.xxxx.xxxx valid from 04/03/2022 08:28:02 to 02/06/2022 08:28:01, issued by Let's Encrypt
23/04/2022 04:53:02.090: Starting Web Server
23/04/2022 04:53:02.106: Added binding with IP=192.168.1.4 and Port=8999
23/04/2022 04:53:02.106: TLS Port is 8999
23/04/2022 04:53:02.122: Web server started with IP 192.168.1.4, port 8999, Docs path: C:\Program Files\Syncovery\WebDocs
23/04/2022 04:53:57.664: Web Server Stopped
23/04/2022 04:55:25.780: Loaded SSL Certificate for *.xxxx.xxxx.xxxx valid from 04/03/2022 08:28:02 to 02/06/2022 08:28:01, issued by Let's Encrypt
23/04/2022 04:55:25.780: Starting Web Server
23/04/2022 04:55:25.780: Added binding with IP=192.168.1.4 and Port=8999
23/04/2022 04:55:25.780: TLS Port is 8999
23/04/2022 04:55:25.812: Web server could not start: Could not bind socket. Address and port already in use or invalid address. Error Code 10049
23/04/2022 14:54:48.473: Web Server Stopped
xxxx= Domain hidden for security
Syncovery v9.47g.
Re: Syncovery Web GUI Error 10049. Web server could not start.
you need to find out how SyncoveryService.exe is started on reboot, for example as a service or as a background scheduler.
The log shows that it was stopped at 04:53:57, but maybe it didn't free the port fast enough so that the new process started a bit later couldn't use it.
tiagocoelho2
SyncoryService.exe started automatic service with local user .\administrator.
OK, in general it should be fine.
There could be a conflict if the service is started later than the tray icon of a logged in user.
Better wait a bit after reboot before logging in.
