Program Used to Compare Files from the Sync Preview
jsusko
Post by jsusko »
Hello, all. I am curious what program you use to compare files in the Sync Preview.
I have tried the 'FC' which comes with windows and also WinMerge (portable version)
They appear to be comparable to me in their terms of speed and accuracy.
So, my question is, are either of these the preferred, or do you all have other suggestions?
Thank you, all.
John
Re: Program Used to Compare Files from the Sync Preview
personally, I use Beyond Compare from https://www.scootersoftware.com/, probably a tool mostly for software developers.
jsusko
Post by jsusko »
Thank you for the information, Tobias. I had forgotten about that one...last time I used it was in 2007.
