Sync errors
c_cooper88
Sync errors
Post by c_cooper88 »
I'm trying to sync a hard drive to Dropbox but I'm receiving lots of errors.
Processing Rate Limiting: {"error_summary": "too_many_write_operations/...", "error": {"reason": {".tag": "too_many_write_operations"}}}, attempt #1 req: POST
Error deleting renamed backup of file to replace on DropBox: resdat:{"error_summary": "path_lookup/not_found/", "error": {".tag": "path_lookup", "path_lookup": {".tag": "not_found"}}}
03/12/2020 04:12:39 PM DropBoxV2: Exception creating folder: Disallowed folder name: /Jobs/2020/October/Hydes  (ETGFTPErrorDoNotRetry) @ 00FA6EA9
I'm getting a large amount of all these errors.
This is extremely problematic as I can't see why the folder name is disallowed as other similar names are fine.
Any help is greatly appreciated.
Thanks, Chris.
Re: Sync errors
the snippets are much too short to work with. Rate limiting errors are normal, and you can ignore them (Syncovery retries appropriately).
Can you send a complete log file to support@syncovery.com? Maybe with some private info removed. But please leave as much info as possible.
c_cooper88
Re: Sync errors
Thank you, I have emailed the file over.
Kind regards,
Re: Sync errors
there are folders with trailing space characters. These are not allowed on DropBox and need to be renamed locally, on your hard drive, before uploading.
