Synology - Some settings won't save
Chad
Post by Chad »
I am currently trialling on a Synology DS918+ NAS.
Most things appear to be working, except that some settings are not saving. In particular the Ransomware Protection and the Keep Old Versions number. I change them, save, and when I check them they are back to their default setting.
Should this occurring, or are there other settings that may be affecting them?
Thanks.
Re: Synology - Some settings won't save
it seems to be a bug in the web GUI. I can confirm that the number of older versions to keep does not save correctly.
But the ransomware percentage seems to save fine for me.
Which Syncovery version are you testing?
I will make an update in the next few days to fix any known web GUI issues (which I can confirm).
Chad
Post by Chad »
Version 9.12 running on Synology DSM 6.2.3-25426 Update 2.
I have released Syncovery 9.15 for Linux now, which fixes the problem where the number of older versions could not be saved.
I have also tested the Ransomware Protection field and it works fine here. It should accept whole numbers from 1 to 99.
