Copying folders only
rathmannm
Post by rathmannm »
is there a way to copy subfolders only but not the root files? For example:
Folder A
Subfolder A
Subfolder B
Subfolder C
File 1
File 2
So I want only Subfolder A-C copied without the File 1, File 2... Is that possible?
Re: Copying folders only
yes, you can use the subfolder selection for this purpose.
Click Choose Folders and Files and either choose all subfolders, or click "All", then right-click the root folder and choose "No files".
Note the checkbox in the top right corner:
X Automatically add future new folders and files to the selection
This will ensure that new subfolders will be automatically chosen.
