Access violations in version 12.4.1
I've attached a number of log files. Almost all of my profiles are failing
- Logs.7z
- (35.77 KiB) Downloaded 128 times
Re: Access violations in version 12.4.1
Thank you, I am working on it!
The error occurs only when "statistics verification" is on for profiles (under Verification in the profile).
A recent changed caused this. I am finalizing a hotfix update now.
The new version 12.4.2 fixes this now.
Thanks for the report!
You may however check if you need the extra statistics verification stage for all these jobs. If not, you can turn it off on the Verification tab sheet.
