Single file backup
Atin90@hotmail.com
Single file backup
How do I select just one file to back up. I can select only folder that i know?
Re: Single file backup
the best way is to type the filename into the Inclusion Masks field, replacing anything else that may be in that field.
On Mac and Windows, you can use the subfolder selection dialog to select files too. Just right-click a folder (or the top), and choose "Selected Files..." and a file selection dialog will popup.
You can get to the subfolder selection dialog via the button "Choose Folders and Files...".
When working with the subfolder selection dialog, please decide if you want the checkmark in the top right chosen or not. This is an important choice:
"Automatically Add Future New Folders and Files to Selection".
So if you really want only one file, you'll want to remove the checkmark.
