SharePoint to Local Move Leaving Folder Structure
alandsman
Post by alandsman »
I'm using the "Move Files to Destination" sync operation mode to bring files down from SharePoint to a local server to be archived. All of the files and file structure copy to the local server successfully, but only the files are deleted on SharePoint. Is there another option I need to select to also automatically delete the subfolders so I don't have to go back and clean them up?
Re: SharePoint to Local Move Leaving Folder Structure
you can try the checkmark "Remove Folders That Were Emptied" in the "Folders" category in the profile.
alandsman
Post by alandsman »
That's it, thank you!
