Binary comparison really slow even using Remember Results
donw146
Post by donw146 »
Please review the log file for this profile to see if there is anything I can do to speed it up. When I watch the profile run it seems like if checks some of the checksums and does a full comparison on other files. I realize that there are a lot of files, some of which are quite large
DG1S3 Family Pictures - 2025-08-23 14.28.59 - 1 copied (369.6MB), Duration 02.27.12, Binary Comparisons. 1183.log.zip
(325.23 KiB) Downloaded 1135 times
Re: Binary comparison really slow even using Remember Results
the database where Syncovery remember previous deletions was empty when this job run was started.
Therefore, it compared 11831 files, which can take a while.
Theoretically it should be faster the next time the job runs.
donw146
Post by donw146 »
I scanned my previous log files. It appears that the database has been empty since July 19. I let almost all of the profiles run to completion so I don't understand why the database isn't getting updated. I've attached several log files from when the database was last updated and several after when it was empty.
Logs.7z
(323.13 KiB) Downloaded 832 times
donw146
Post by donw146 »
Here are the scan results going back to Jun:
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-08-23 14.28.59 - 1 copied (369.6MB), Duration 02.27.12, Binary Comparisons. 1183.log 1,907 KB LOG File 2025-08-23 16:56:21 2025-08-23 14:28:59 2025-08-24 12:48:30 1
45 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (0 Folders, 0 Entries, DB size: 2,768 kB)
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-08-17 17.28.50 - 10 copied (2.6MB), Duration 01.42.29, Binary Comparisons. 11821.log 1,906 KB LOG File 2025-08-17 19:11:27 2025-08-17 17:28:50 2025-08-23 17:03:42 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-08-10 16.19.20 - 8 copied (7.4MB), Duration 01.21.59, Binary Comparisons. 11813,.log 1,905 KB LOG File 2025-08-10 17:41:27 2025-08-10 16:19:20 2025-08-10 17:41:27 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-08-03 22.10.45 - 12 copied (59.5MB), Duration 01.22.14, Binary Comparisons. 1180.log 1,904 KB LOG File 2025-08-03 23:33:06 2025-08-03 22:10:45 2025-08-03 23:33:06 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-26 23.49.13 - Nothing to do, Duration 01.19.17, Binary Comparisons. 11801, Su.log 1,901 KB LOG File 2025-07-27 01:08:38 2025-07-26 23:49:13 2025-07-27 01:08:38 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-26 16.48.43 - Nothing to do, Duration 01.19.33, Binary Comparisons. 11801, Su.log 1,901 KB LOG File 2025-07-26 18:08:23 2025-07-26 16:48:43 2025-07-26 18:08:23 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-26 00.40.00 - 3 copied (6.9MB), Duration 00.04.52, Binary Comparisons. 4048, .log 652 KB LOG File 2025-07-26 00:44:58 2025-07-26 00:40:00 2025-07-26 00:44:58 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-20 16.00.16 - Nothing to do, Duration 01.18.52, Binary Comparisons. 11798, Su.log 1,900 KB LOG File 2025-07-20 17:19:15 2025-07-20 16:00:16 2025-07-20 21:21:08 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-20 10.39.46 - Nothing to do, Duration 01.21.25, Binary Comparisons. 11798, Su.log 1,901 KB LOG File 2025-07-20 12:01:18 2025-07-20 10:39:46 2025-07-20 12:01:18 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-20 10.31.43 - Nothing to do, Duration 00.02.15, Binary Comparisons. 3909, Suc.log 628 KB LOG File 2025-07-20 10:34:04 2025-07-20 10:31:43 2025-07-20 10:34:04 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-20 01.22.30 - 37 copied (93.5MB), Duration 09.08.53, Binary Comparisons. 1176.log 1,901 KB LOG File 2025-07-20 10:31:31 2025-07-20 01:22:30 2025-07-20 10:31:31 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-20 00.05.13 - Nothing to do, Duration 00.13.06, Binary Comparisons. 4417, Suc.log 711 KB LOG File 2025-07-20 00:18:31 2025-07-20 00:05:13 2025-07-20 00:18:31 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-19 22.20.56 - Nothing to do, Duration 01.23.52, Binary Comparisons. 11761, Su.log 1,919 KB LOG File 2025-07-19 23:44:56 2025-07-19 22:20:56 2025-07-19 23:44:56 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-19 20.48.01 - 272 copied (656.4MB), Duration 01.32.40, Binary Comparisons. 11.log 1,923 KB LOG File 2025-07-19 22:20:48 2025-07-19 20:48:01 2025-07-19 22:20:48 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-19 15.55.10 - 4479 copied (25.8GB), Duration 01.19.02.log 826 KB LOG File 2025-07-19 17:14:17 2025-07-19 15:55:10 2025-07-19 17:14:17 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-19 15.13.35 - 3 copied (9.6MB), Duration 00.03.12, Binary Comparisons. 7279, .log 1,206 KB LOG File 2025-07-19 15:16:51 2025-07-19 15:13:35 2025-07-19 15:16:51 1
34 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (322 Folders, 8249 Entries, DB size: 4,416 kB)
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-07-13 16.20.04 - 15 copied (55.8MB), Duration 00.37.50, Binary Comparisons. 7264.log 1,206 KB LOG File 2025-07-13 16:58:01 2025-07-13 16:20:04 2025-07-13 16:58:01 1
34 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (321 Folders, 8233 Entries, DB size: 4,416 kB)
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-06-30 14.15.11 - Nothing to do, Duration 00.01.20, Binary Comparisons. 7264, Suc.log 1,203 KB LOG File 2025-06-30 14:16:35 2025-06-30 14:15:11 2025-06-30 14:16:35 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-06-25 22.09.42 - Nothing to do, Duration 00.01.16, Binary Comparisons. 7264, Suc.log 1,203 KB LOG File 2025-06-25 22:11:02 2025-06-25 22:09:42 2025-06-25 22:11:30 1
34 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (321 Folders, 7703 Entries, DB size: 4,416 kB)
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-06-21 15.37.11 - Not started (F). Preview Canceled.log 358 KB LOG File 2025-06-21 15:39:33 2025-06-21 15:37:11 2025-06-21 15:39:33 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-06-20 21.19.27 - Not started (F). Preview Canceled.log 2,164 KB LOG File 2025-06-20 21:42:44 2025-06-20 21:19:27 2025-06-21 15:08:25 1
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-06-20 21.06.47 - Not started (F). Preview Canceled.log 1,869 KB LOG File 2025-06-20 21:14:13 2025-06-20 21:06:47 2025-06-21 15:11:07 1
35 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (321 Folders, 7703 Entries, DB size: 4,416 kB)
C:\ProgramData\Syncovery\Logs\DG1S3 Family Pictures - 2025-04-08 21.58.42 - Nothing to do, Duration 00.01.14.log 2,349 KB LOG File 2025-04-08 22:00:42 2025-04-08 21:58:42 2025-06-21 15:10:15 1
33 Using reference database in file C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb (321 Folders, 7703 Entries, DB size: 4,416 kB)
apparently multiple profiles are sharing the same database, and the path conflicts cause Syncovery to delete it.
You can see it here in the log file:
DB offsets mismatch, left=\Family, right=\..
Closing database C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb
15:55:10.843 Database closed
Deleted DB: C:\ProgramData\Syncovery\Database\DG1S3 Family Pictures.syncfdb
As a solution, please go to the Program Settings dialog, tab sheet "DB", and choose:
-> Never allow two profiles to share the same database
Some background information: profiles sharing a database can occur if a profile is duplicated, or edited and the name changed. Syncovery may then use the same database for two profiles. It should actually ask you what to do with the database, but that question is probably so confusing that most users don't know what to choose.
I hope this will fix the problem.
Finally, despite Syncovery offers the feature, I don't actually recommend keeping "Binary Comparison Of Existing Files While Building File List" chosen permanently. Even together with "Remember Results", it's meant as a temporary feature to verify your database from time to time.
It's usually better to use only "Verify copied files". Once the upload has been verified, you can trust the S3 servers not to corrupt your file.
donw146
Post by donw146 »
It turns out that "Never allow two profiles to share the same database" was already checked in the program settings.
I'm taking your advice and switching all relevant profiles to "Verify copied files"
