Scheduler OFF ... or is it
ChaosX
Post by ChaosX »
Occasionally when I reopen Syncovery from the W11 tray, the Next Run column shows “Scheduler Off” for all profiles. But when I select the Scheduler tab, it indicates that the scheduler is running (the “Stop Scheduler” button is present). If I then switch back to the profile view, the “Next Run” column is properly populated.
All I've done is switch form Profile tab to Scheduler tab, and back to Profile tab.
Why does the Next Run column initially show “Scheduler Off”? Is it slow to update from waking from the tray? I feel as though I have not properly set this up?
I'm using “Background Scheduler” if that matters. Thank you!
Re: Scheduler OFF ... or is it
yes, it can sometimes be necessary to switch between the tabs to update the display. That is a fairly normal procedure in using the program.
Ideally it would not be needed, of course. Please check if a Syncovery update is available too.
ChaosX
Post by ChaosX »
Thank you. There was an update.
Coincidentally, after the update ran, Syncovery opened with the scheduler turned off. Perhaps by design.
