Ports Needed To Access Box.com With Syncovery
Clyde91
Post by Clyde91 »
I am trying to access box.com with Syncovery using Box as protocol. I have allowed all box addresses and syncovery.com on the firewall using port 443 per box instructions, and find I am unable to connect still. Is there another port(s) or url that needs to be allowed?
I am seeing the NOTE:
Cannot access ext://Box
(Aborting (QUWS) at 0000000001642F98)
Regards,
Virgil
Re: Ports Needed To Access Box.com With Syncovery
only port 443 on these URLs:
www.box.com
api.box.com
upload.box.com
If problems remain, please try creating the job without using any Browse button and run it. Then you'll get a log file that you can analyze or post here or send to support@syncovery.com (after removing any confidential info).
