HTTP ERROR 409 Conflict - Name already exists
Re: HTTP ERROR 409 Conflict - Name already exists
the new version 10.13.5 is now available, and it reduces the chunk size for OneDrive/Sharepoint uploads from 60MB to 32MB, and also falls back to 8 MB in case of any transfer errors.
Would be very interested in knowing if this helps at all?
Paradoxical
Post by Paradoxical »
Are those parameters automatically applied or do I have to configure something elsewhere?
yes, these chunk sizes are hardcoded and not configurable, so you only need to install the update.
Paradoxical
It didn't work either.
I'm gonna try using files with different sizes to know which is the max size OneDrive allows...
Edit:
Max size allowed is 32 MB.
this is very unusual. It means that the chunked upload isn't working. Only file that are uploaded as one part, up to 32 MB, work.
I have no idea why, it doesn't happen with my OneDrive account, and the upload code is also pretty old, nothing significant has changed in a few years.
I think something must be broken on the servers that are responsible for your OneDrive account.
Paradoxical
Definitely. Thanks again for your support.
