PCloud: Invalid files
Re: PCloud: Invalid files
Test Integrity is faster than doing a normal run with the checkmark "Binary Comparison of Existing Files" on the tab sheet Comparison->More in the profile.
mareike1988
Post by mareike1988 »
I am still running into problems.
I have 32mb file in my backup.
Then: Test Integrity shows an error. Manual download and unzipping the encrypted-zip file does not succeed. So the problem is confirmed. The file at PCloud is only 7MB of size.
So there is a problem.
The zip file was uploaded to Pcloud via Syncovery, but I cannot find this action in the log files.
Edit: Only 50 log files were kept...
How is this possible?
How can I diagnose this further?
mareike1988
If I run the sync in "attended" mode, Syncovery shows that it won't make an update to this file.
mareike1988
OK maybe I uploaded some files with the old settings and did not delete them. I will delete the integrity error files and continue uploading,
yes if you use the Auto-Resume setting with interim filenames it cannot happen.
mareike1988
I have successfully worked now with local file to PCloud using the Resume-Function.
However:
I have again lots of invalid files on the PCloud sides when copying from Dropbox as source (left).
Test Backup Integrity throws Invalid Files - and yes manually downloading the ZIP confirms the PCloud-ZIP-File as corrupt.
Setting Dropbox LEFT
- Resume ON (although I don't see how this is relevant?)
Setting PCloud RIGHT
- Resume ON
- Date in Filename ON
Other settings
- verify copied files ON
- encryption ON
I did a test:
Backup of large file (150MB, 2022-11-30 17.51.18.mov ), then cancelling during the upload part....
and on Pcloud now a 14 MB (2022-11-30 17.51.18.d20221130-u165118.mov.s183649654.zip) file exists. obviously invalid.
mareike1988
LOG
Syncovery v9.48i, build 413 (64-bit)
Licensed to: ###
Running on : M-MacBook-Air
Running as : UsernameMacOs
System Info: macOS v12.6.1, Build 21G217
Log for profile SyncDropboxOnlineto_PCloud TEST, started at 13:25:34 on 16.12.22
LEFT: ext://DropBox/Test
RIGHT: ext://PCloud/Test
The profile is run in attended mode.
13:25:34.692: Opening Database: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/SyncDropboxOnline_to_PCloud TEST.syncsq3db
13:25:34.741: Database Opening Complete
Connecting with DropBox
Using OpenSSL 1.1.1h 22 Sep 2020: /Applications/Syncovery.app/Contents/MacOS/libssl.1.1.dylib, /Applications/Syncovery.app/Contents/MacOS/libcrypto.1.1.dylib
Connecting with PCloud
Exact Mirror Mode is being used.
Using reference database in file /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/SyncDropboxOnline_to_PCloud TEST.syncsq3db (0 Folders, 0 Entries, DB size: 32.768 Bytes)
Scanning Folders Started At 16.12.22 13:25:35
16.12.22 13:25:34 DropBoxV2: Verifying Access Tokens
16.12.22 13:25:35 DropBoxV2: Connect Successful
16.12.22 13:25:35 PCloud: Connect Successful
13:25:35.786: Opening Database: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox]v3.syncsq3db
13:25:35.911: Database Opening Complete
Using Cloud Cache Database: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox]v3.syncsq3db (0 Folders, 0 Entries, DB size: 32.768 Bytes)
Getting changes history for dropboxv2_Dropbox from checkpoint
Item count in base folder: 0
At end (1), FDirectorySize=0 -> FDirectorySizeWithStartAndEndHeader=32
16.12.22 13:25:35 Getting Listing from DropBox, using JSON Cache file /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox].D41D8CD98F00B204E9800998ECF8427E.json
16.12.22 13:25:35 Getting Listing from DropBox, Part 1
Confirmed no more changes to process.
16.12.22 13:25:36: Received 2 pages of changes.
16.12.22 13:25:36 Using JSON Cache File: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox].D41D8CD98F00B204E9800998ECF8427E.json
16.12.22 13:25:36 Opened JSON Cache File: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox].D41D8CD98F00B204E9800998ECF8427E.json, size is: 811
Writing the folder and file listing to a new cloud cache database.
Scanning folders took 00:00:02 (hh:mm:ss) for 1 folders
PCloud Listing Size: 357 Bytes
Scanning folders took 00:00:00 (hh:mm:ss)
Free Space on right side: Not checked, needed: 183.650 kB
Main Copying Phase Started At 16.12.22 13:25:41
16.12.22 13:27:53 PCloud: Starting upload of 2022-11-30 17.51.18.d20221130-u165118.mov.s183649654.zip (183221339 Bytes)
16.12.22 13:30:42 PCloud: Exception uploading 2022-11-30 17.51.18.d20221130-u165118.mov.s183649654.zip: Aborting (SkStat) (ETGFTPCanceled), CP:SynHttpsPutRaise4
16.12.22 13:30:42 PCloud: Final exception uploading 2022-11-30 17.51.18.d20221130-u165118.mov.s183649654.zip: Aborting (SkStat) (ETGFTPCanceled) (1 attempts uploading stream) (EFinalCloudException)
Binary Verification succeeded
Encrypting (AES256) /var/folders/sq/j89wpl1573n566vd13f3qy4m0000gn/T/TGTEMP50621-284913664-1.$$$ to /var/folders/sq/j89wpl1573n566vd13f3qy4m0000gn/T/Backup 470.4648019456.33554436.123145587224576-1671193660639-785987762.zip
name in ZIP: 2022-11-30 17.51.18.mov
13:27:53.347 Testing /var/folders/sq/j89wpl1573n566vd13f3qy4m0000gn/T/Backup 470.4648019456.33554436.123145587224576-1671193660639-785987762.zip
16.12.22 13:30:42 SynHttpsPut: Aborting (SkStat) (ETGFTPCanceled) @0000000103E14591, ResultCode=0, Result=
16.12.22 13:30:42 ERROR (ETGFTPCanceled): Aborting (SkStat) @ 0000000103E14591, Thread ID: 123145587224576, CP: SHPutEX:Aborting (SkStat) (SynHttpsPut)
Exception Operation Canceled at 0000000102A615E0.
Filename: /var/folders/sq/j89wpl1573n566vd13f3qy4m0000gn/T/Backup 470.4648019456.33554436.123145587224576-1671193660639-785987762.zip
Checkpoints: TGGetOrPutEX:Operation Canceled
Main Copying Phase Ended At 16.12.22 13:30:43 And Took 00:05:01
Closing database /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/DropBoxV2_Cache_Test[dropboxv2_Dropbox]v3.syncsq3db
13:30:43.363 Database closed
Closing database /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/SyncDropboxOnline_to_PCloud TEST.syncsq3db
13:30:44.437 Database closed
Reference database closed: /Users/UsernameMacOs/Library/Application Support/Syncovery/Database/SyncDropboxOnline_to_PCloud TEST.syncsq3db (1 Folders, 1 Entries, DB size: 32.768 Bytes)
Operation Canceled
SUMMARY
Short Results: INCOMPLETE: 0 copied of 1, Errors with 1 File(s)
Operation completed at 13:30:44 on 16.12.22
Total duration: 00:05:09
Errors with 1 File(s).
Local time zone offset: 1.0 hours.
Internet protocol timeout: 60 seconds
Max. Internet protocol retries: 2
SQLite version: 3.37.0
Profile Settings From /Users/UsernameMacOs/Library/Preferences/Syncovery.cfg
[General]
Name=SyncDropboxOnline_to_PCloud TEST
LastModified=16.12.22 13:25:09
Disabled=Yes
LeftPath=ext://DropBox/Test
RightPath=ext://PCloud/Test
Subfolders=Yes
LeftToRight=Yes
RightToLeft=No
UseSubfolderSelection=No
[Comparison]
AdjustFolderTimes=Yes
SizeConflictAction=scaCopy
[Exact Mirror Config]
ExactMirrorDeletes=Yes
ExactMirrorReplacesNewerFiles=Yes
[Files]
VerifyAfterCopy=Yes
MaxParallelCopiers=1
[Internet]
LeftFTPSettings=Ext:ExtProt=DropBoxV2,Flags=UTF8+UTC+DetectTimezone,"Proxy=no",Lib=0
LeftExtendedProtocolName=DropBoxV2
LeftUser=Dropbox
RightFTPSettings=Ext:ExtProt=PCloud,Flags=UTF8+UTC+DetectTimezone,"Proxy=no",Lib=0
RightUser=PCloud_
RightExtendedProtocolName=PCloud
[Inclusion Masks]
FileMasks=(all);
[Exclusion Masks]
ExcludeFileMasks=(none);
[Safety->Attended]
WarnReadOnly=No
WarnLarger=No
WarnNewer=No
[Safety->Unattended]
UnattendedDeleteMaxPercent=10
[Schedule]
ScheduledNormally=Yes
RepeatAfter=Yes
OrigTimeOfDay=15:43:16
Mins=180
[Schedule->More]
HandleMissedJobs=No
[Special]
SecurityFlag=85
OwnerMode=CopyFromSource
PermissionsMode=CopyFromSource
[Special->Database]
NameForDatabase=SyncDropboxOnline_to_PCloud TEST
DBLeftBasePath=ext://DropBox/Test
DBRightBasePath=ext://PCloud/Test
[Versioning]
FilenameEncoding=Yes
[Waiting & Retrying]
WaitForAccess=No
TolerateDisconnections=No
RetryFileList=No
[Zipping]
ZipFilesIndividually=Yes
EncryptionLevel=6
Default System Codepage: 65001
Email Notification Settings:
Email Notification is OFF.
copying from one cloud protocol to another is surely different than uploading from local. I think the latest Syncovery update fixes your problems. You can turn off "Filename Encoding" but you don't have to. You do not have to re-do any of your backup, because encoded filenames can be freely mixed with non-encoded ones.
There is no need to add the timestamp to filenames on PCloud any more, because Syncovery sends the original modification date to PCloud when uploading a file.
mareike1988
thanks OK. I have created a new profile and NOT turned the "date in filename" ON, but I did activate "resume" (both settings for PCloud).
I have to say this is quite advanced knowledge to have.
What other settings can one not use to not harm the integrity of the file transfer to Pcloud?
mareike1988
Sorry but please make a test: Dropbox to PCloud
Resume ON, Encryption ON, Filename Encoding OFF
Transfer a large file, and then during the PCloud-uploading stage cancel the process.
100% an invalid ZIP-File is on the right-PCloud-side.
