feature request
Re: feature request
Syncovery 11 build 3 is out now. I added a manager for cloud and Internet Protocol accounts. This allows managing them in a central place rather than having passwords in each profile.
The main new features for Syncovery 11 are now all there.
I will add the separate versioning folders in the next build.
IMTheNachoMan
Re: feature request
Awesome. Thank you!
Re: feature request
Syncovery 11 build 4 is now available.
It allows specifying separate versioning folders for the left and right sides.
In addition, profiles can be colored on the Profile Overview, and notes/comments can be entered for each profile (on the Information tab sheet in the profile).
Minor visual improvements have also been made.
IMTheNachoMan
Re: feature request
Just upgraded. Love it. This makes things a lot easier for me. Otherwise I had to hack it with a lot of symlinks.
Re: feature request
I now have Release Candidate 1 on the Windows download page and would be grateful for testing!
Thanks.
Thanks.
IMTheNachoMan
Re: feature request
Thanks. Working well so far.
Any idea when the left/right version option will be available for Linux?
Re: feature request
I would hope before the end of the year. The GUI changes are huge and I need to figure out how to do it for the web GUI.
IMTheNachoMan
Re: feature request
Got it. Thank you!
If it helps, I'll explain what I am doing and why.
I have one central linux server, 2x windows machines, and 1x linux desktops.
The 2x windows machines and 1x linux desktops have access to a samba share on the linux server (documents). On all 3 of these machines, I am running Syncovery to keep a 2 way sync of the documents folder between the linux server and the client machines.
I want to use different versioning folders on both sides such that on each machine there is a local folder with the older versions.
Say the file is updated on the central server, then when all the clients do a sync, before they pull the newer version, they'll move their copy of the file to C:\some\other\folder.
Say the file is updated on a client, then when the client does a sync, it'll move the central server file to /some/folder/that/is/not/documents.
I hope that makes sense.
IMTheNachoMan
Re: feature request
Out of curiosity, do you know if you'll ever add Real Time Sync to Linux?
Re: feature request
Yes I will try it but Linux doesn't have a good API for it.
