How does Syncovery compare left and right files if you use compression and encryption?
Re: How does Syncovery compare left and right files if you use compression and encryption?
yes that's completely correct. You can freely change compression settings. Syncovery won't re-upload all the files if you change settings. The new settings will only take effect for new and modified files that need to be uploaded.
