Strange behavior of Smart Tracking mode in combination with "Flat Right Side (no folders)"
Silicon
Re: Strange behavior of Smart Tracking mode in combination with "Flat Right Side (no folders)"
Post by Silicon »
Hello Tobias
Thank you. I’ll test it asap.
BR,
Silicon
Silicon
Post by Silicon »
Hello Tobias
I have finaly found a moment to test new version 10 dev08 :roll:
New feature I have requested is working as expected.
Thank you again!
I have identified a small bug during my tests: when you try to export Profiles (in a Group), only first one is exported. And it doesn't matter if you export them one by one, or alltogether (checked or selected), or which file format (ini, xml, cvs) you choose.
I can PM you detail, if you want.
BR,
Silicon
thanks, I will look into it! Due to the grouping changes in v10, I need to test all these functions once more. I'm sure I will be able to produce the issue here.
this has been fixed in Syncovery 10.dev.09.
