Support for AWS Signature Version 4.
Re: Support for AWS Signature Version 4.
I will also just add an Ini file option to always use Signature V4 in the next Syncovery update!
actually for this issue you don't need to send me anything, the next version will most likely fix it.
the new versions 8.67c and 9.00a should now be able to recognize the need for signature V4, and you can also enforce it by adding
AWSAlwaysUseSignatureV4=1
to the [Main] section of the Syncovery.ini file.
