Recovery from S3
steinitz
Re: Recovery from S3
Post by steinitz »
Congratulations on releasing 9.23, Tobias.
Thanks for your detailed instructions and suggestions for the recovery profile -- very helpful and a great reference. Such a reference could be essential in the heat of an actual disaster-recovery scenario. In fact, I just had an idea...
What if the backup could store a recovery profile which you could use, somehow, as the default recovery profile? Sounds like hard work for the developer :D
I'll try a server recovery later today...
steinitz
Post by steinitz »
The restore gets the error "Cannot access S3 - cannot load samba library". I can find instructions for installing the samba library but they seem complicated.
Would anyone know the simplest way to allow restore from S3 on a fresh ubuntu image?
S3 does not use Samba. I think the profile isn't set up correctly. Can you click the Internet button and make sure that the S3 protocol is chosen?
If problems remain, please post a log file or send to support@syncovery.com.
steinitz
Post by steinitz »
Hello
The full restore to a freshly-imaged server completed successfully. A useful and unique capability among backup systems. Bravo Tobias.
Note that the issue I had with the S3 protocol requiring Samba appeared to be a minor problem with the web UI. To solve it, a little clicking around in the S3 options "reminded" the interface that it wasn't a Samba source.
An excellent result - thanks for your help.
