Feat request for encrypted files / logging
solemgar
Post by solemgar »
Hi!
Would it be possible that logs for encrypted files show the paths and filenames unencrypted? Otherwise it's very hard to follow which operations are happening.
Thanks!
Re: Feat request for encrypted files / logging
yes, in general they do that - or they show both the encrypted and the unencrypted name.
Can you post a specific example of a few log lines where the clear text names are missing?
Also mention the Syncovery version please.
solemgar
Post by solemgar »
Hi Tobias! Thanks for the quick reply, these are some log snippets
MOVE ext://Google Drive/Backup_Marcos/3~y;NJckDt}JH}@^L~#st{vM81tM-W_yLu4U@7bKj8hrRt)';Od{=ydxNf;9PE;pDC!.s80041726673.part0001
  to ext://Google Drive/Backup_Marcos/#W;~'VFU!aJfSVl-EQiK
Uploading ext://Google Drive/Backup_Marcos/#W;~'VFU!aJfSVl-EQiK/uDn}q#HOPzoeUm5fkfx~TVn`LAa;KTtBdl#nVEA4AsYyIG7irBdK8I-pEL2W;Z`=v1_j5peIA3x51mKVE.s25852789771.part0010 (    2 GB)
RENAME ext://Google Drive/Backup_Marcos/=49IwegujbEWTSni3}0Ag!J;m3Pp^il1Y1mL3jb(7$w=HM@sXwM=}$j33d3.s71019595287.part0020
    to 8YTjZaJyMM[(P[2J+Kn2(~)PA&JcAfOiY%~de0z=IE=HdfBZ=V&{Y[`kC.s71019595287.part0020
Syncovery is latest available (9.13b). Maybe this could be set as a configurable option if some people prefer the encrypted logging?
Thank you! (and this is not urgent at all!)
solemgar
Post by solemgar »
Hi Tobias, did you have time to take a look? Thanks!
It would help a lot specially with the deletions
the snippet is too short. This is moving a part of a larger file. The unencrypted filename is surely logged also, a bit further above or below.
But the best way to get a complete listing is to use "Output Left/Right File Listings" on the Program Settings dialog, tab sheet Logs. This will give you a pretty HTML file listing with encrypted and clear text file names. But remember to turn the option off when not needed, because the full listings will be created every time the job runs and never cleaned up automatically.
solemgar
Post by solemgar »
Thanks Tobias! I'll check this out and report back
solemgar
Post by solemgar »
Thanks Tobias, indeed the html listing has the unencrypted file names and helps a lot. Thank you!
