Filename Encryption and Decryption Algorithm
rearward
Post by rearward »
/DECRYPTNAMES Command Line Parameter works great!
Thank you for adding this!
Is it possible having an option that exports the list into TSV?
Just two columns would be enough: Encrypted Name and Decrypted Name
It would be great for partial retrieval from a remote untrusted location.
And is it also possible to have encryption/decryption algorithm for the file name?
Can I encrypt a file name via native command line tools?
Re: Filename Encryption and Decryption Algorithm
many thanks, I will consider adding these features.
I can't disclose the algorithm at this time because it contains some code from third party libraries which I have licensed.
rearward
Post by rearward »
Hi Tobias,
Any update on this?
